It is currently Sat Jul 26, 2025 7:55 am
 Post subject: CA glue bleed
PostPosted: Sun May 22, 2022 6:31 pm
I usually glue my rosettes in with CA glue. I seal the channel with a coat of shellac first, then put in rosette dry and then flood with CA.
The last top I did was red cedar and the CA bled well into the top and no amount of sanding will remove it.
Very frustrating as it ruined the top and all my hard work.
Any suggestions appreciated!
thanks
fred
 Post subject: Re: CA glue bleed
PostPosted: Sun May 22, 2022 7:00 pm
If it stayed clear, there's a chance it'll disappear under finish.
You might try applying a little finish to the area to see what it'll actually look like.
These users thanked the author Jim Watts for the post (total 2): frwilliams (Fri May 27, 2022 8:01 am) • Pmaj7 (Wed May 25, 2022 10:33 am)
PostPosted: Sun May 22, 2022 7:23 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Been there. You can preview your work under finish after wiping with naphtha, but the likelihood is the bleed will still be visible.
After a similar experience, I did a series of experiments using a ruined WRC top. Conclusion was that CA and epoxy should not be on the same bench as WRC. Water soluble glues only. Fish works well for both rosettes and binding.
These users thanked the author Tim Mullin for the post (total 2): frwilliams (Fri May 27, 2022 8:00 am) • Pmaj7 (Wed May 25, 2022 10:34 am)
PostPosted: Mon May 23, 2022 2:02 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I glue my wood rosettes in with Duco. It is invisible under finish. Water base glues tend to swell the rosette, which may make it too tight to install.
Sent from my SM-G950U1 using Tapatalk
These users thanked the author John Arnold for the post (total 2): frwilliams (Fri May 27, 2022 7:54 am) • Pmaj7 (Wed May 25, 2022 10:36 am)
PostPosted: Mon May 23, 2022 2:22 am
I used Titebond original and it was great in that if my stuff had a bit of a sloppy press fit Titebond would also swell things a bit making a nice, snug fit. And of course I had lots of time to deal with getting things in place and clean-up.
I never used CA to build beyond for fret work and one little drop for the nut.
Whoops I lied. I also used one drop of ca in the middle of the heel cap to hold it in place as the circle of Titebond around it set the heel cap in place.
These users thanked the author Hesh for the post (total 3): frwilliams (Fri May 27, 2022 7:59 am) • Pmaj7 (Wed May 25, 2022 10:37 am) • joshnothing (Mon May 23, 2022 5:56 am)
PostPosted: Mon May 23, 2022 3:12 am
Some observation on classical rosettes with water soluble glue. You can test this on a cutoff of the rosette end before installing.
I have had some high-quality prefab rosettes that expand irreversibly when wetted and the color does not fade. This is great. Install in a very slightly oversized channel with Elmers school glue and swab the rosetted with a wet cloth. Then cover with saran, then a board, then a weight. Do not clamp, so the expansion is not restricted.
Cheaper rosettes expanded reversibly, and the colors faded. Reversible expansion resulted in the rosettes filing the channel, but then gaps formed at various locations in the pattern as the glue dried.
The test in advance is to cut off a bit of the rosettes that will be under the fingerboard. It does not matter if some of the cutoff crumbles off. Put the cutoff on a scrap board with Elmers school glue, mark the width with a pencil line on the board, wet the rosette scrap, cover with saran, another board and a weight. After a while, but before it is dry, peek at the scrap and you will see that it expanded past the pencil marks. Replace the weights and let it dry. Then if the scrap shrinks back to the original pencil marks, the installed rosette will have a tendency to shrink back and leave gaps. You may also be able to observe if the colors fade or run.
These users thanked the author wbergman for the post: frwilliams (Fri May 27, 2022 8:02 am)
PostPosted: Mon May 23, 2022 6:01 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
flooding it could be the culprit.
use no more glue then you need.
glue on the top may have seeped in to it.
Mike Collins
These users thanked the author Mike Collins for the post (total 2): frwilliams (Fri May 27, 2022 8:02 am) • Pmaj7 (Wed May 25, 2022 10:38 am)
PostPosted: Mon May 23, 2022 9:30 am
I have had this happen too and there is no way to recover from it. The trick is - two coats, three even better, of shellac and also shellac around the area too not just in the channel. It's a hard lesson learned.
These users thanked the author jfmckenna for the post (total 2): frwilliams (Fri May 27, 2022 7:56 am) • Pmaj7 (Wed May 25, 2022 10:39 am)
PostPosted: Thu May 26, 2022 5:22 pm
I was given a great tip in avoiding CA bleed and yellowing when using it for rosettes and bindings. Seal with vinyl sealer and never shellac. Shellac + CA = yellowing and bleed. I literally flood my rosette channels and binding channels with Cardinal vinyl sealer with emphasis on the end grain portions. I allow a minute or so for it to wick into the wood and then blow the excess out with an air nozzle. Allow a good few hours for drying (I place the guitar or uke in an air stream from a fan) and it is very effective. I learned this trick from a PRS employee and have done many rosettes on cedar, redwood & spruce with no bleeding or yellowing. From my past experience, shellac is a horrible sealer for CA and even worse under nitro.
These users thanked the author Mike Franks for the post (total 2): frwilliams (Fri May 27, 2022 7:57 am) • Tim Mullin (Thu May 26, 2022 5:27 pm)
PostPosted: Thu May 26, 2022 5:40 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
That’s a great tip, Mike. In my experiments sealing western redcedar I did try full strength nitro, but that’s still mostly solvent. The vinyl sealer would have a much higher solids content, so it makes sense it would seal better. I still have my test WRC top, so I’ll be sure to test vinyl sealer along side the other samples. Thanks again!
These users thanked the author Tim Mullin for the post: frwilliams (Fri May 27, 2022 7:57 am)
PostPosted: Thu May 26, 2022 6:09 pm
super glue and tops don't work adding another step by applying shellac isn't needed Like John Arnold Duco had been my rosette glue of choice for 20 yrs.
CA will stain spruce. The I do this the less I use CA
These users thanked the author bluescreek for the post: frwilliams (Fri May 27, 2022 7:58 am)
PostPosted: Fri May 27, 2022 8:54 am
After that one time I had bleed I thought about abandoning CA but then I did a bit of testing and with 3 coats of shellac I do not see any discoloration at all. CA is just so easy to use it's hard to give it up. Once you have all your pearl and wood lines in you just zap it with thin CA and set it in place. For those that use Duco what do you do? Do you place pearl in one by one as you go around?
These users thanked the author jfmckenna for the post: frwilliams (Wed Jun 01, 2022 8:06 am)
Users browsing this forum: Chris Ide and 22 guests
